Why won't my tv auto program?
Why won’t my Samsung tv auto program?
Update (07/07/2020)
Model # UN40H5003
Auto scan for channels
Antenna connection.
Note: Tv less than 3 yrs old when stopped working properly. I expect a tv to last longer. I know you will make this right. Thank you
Это хороший вопрос?
Счет 0
2 Комментариев
Hi,
What is the model number of the TV?
By "auto program" do you mean auto scan for available TV channels?
If so are the channels from an antenna connections or a cable connection?
из
Still not working. 1 channel. Can’t believe a Samsung tv does not last even 3 years. I have done everything ypu have asked of me and still nothing. You need to make this right or direct me to a person that will help.
Thank you
Joy
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi,
Have you checked that the TV is setup to receive TV signals from an antenna or a cable service i.e. Air or cable?
Here’s how to do this in your TV. Scroll down to Memorizing Channels
Был ли этот ответ полезен?
Счет 2
5 Комментариев:
Hi @ joy palmieri
Is the TV getting the signals from an antenna or a cable "box" you didn't say?
из
its placed on antenna under settings
из
why does it keep stop programming and immediately shut off
из
the tv will only auto scan for channels up to 4 to 6 % then shut off so it only has 3 tv stations
из
why did this conversation just stop samsung ?
the lose of channels now 2nd august 2024 is happening across kent ... this morning auto tune even disappeared from view or use ? .. yes i have a samsung tv
i read that the bbc suggest unplugging the aerial and using auto tune (knowing the transmitter name) ... is this going to fix the channels just disappearing suddenly?
we are in the olympics window and the bbc channels in particular are disappearing
из
Добавьте свой ответ
joy palmieri буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 23
За всё время: 2,947
