The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623вопросов Показать все
How come there is an X where the battery is?
I replaced my battery in my MacBook Air 2015. It turned on and there is now an x in the battery icon on my laptop. It also says with my WiFi no hardware connected. How do I fix this? Thanks
Это хороший вопрос?
Оценка 0
1 Комментарий:
Lets get a better idea on whats happening with the battery. Install this gem of an App! CoconutBattery with your MAgSafe charger plugged in take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из
Добавить комментарий
1 ответ
Your WiFi issue is a bit more involved as we just not know if the AirPort board has failed or if the antenna has become disconnected or something worse!
Lets open up the system and inspect the logic board and the Airport board. Review this guide MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement Do you see any corrosion or other damage? If you do post some pics so we can see whats needed.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
aimee будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 52
