Abused 3GS, potential water damage, no backlight function
Hello, I have searched the questions & have not come across one to match my scenario.
iPhone has been thrown, (by ex gf) in otter box case but has survived with the digitizer, lcd & backlight working fine. Then one day I dropped it half a foot while trying to plug it in at work & the backlight went out. LCD & digitizer work as I can see the icons they are just annoying to use.
The water damage came from putting it above the shower head for music & it dropped, (while in the otter box). Also my daughter got yogurt on the case and poured water on it to 'clean it up'. But both times it continued to work, (backlight)
Are the backlight bulbs built into the lcd and could they have been knocked loose? Is a new lcd the answer? Thanks!
- No water damage on board, light still comes and goes. Could this be a coil issue?
Это хороший вопрос?
3 Комментариев
Forgot to mention, the backlight started working again randomly 2 weeks ago. I unlocked my phone & it was light. It only stayed lit for a short while then would black out, but got where it would stay on. It started only lasting just for the lock screen & would vibrate a few times for no reason. I awoke the next morning & it was black again for good.
из Jeremy
replaced lower assembly for new speaker (water damage) & saw no corrosion on board/connections but will open it again to look in specific spots & confirm.
из Jeremy
The best person to ask about this phone is pollytintop. check on the user profile for an email address....if anybody knows iphones', it's pollytintop ;-)
из oldturkey03
