A small white or black laptop with the word Acer written in silver on the outside cover. The top has a woven fabric texture to reduce glare.
3вопросов Показать все
Is there a CMOS battery?
Hello !
I have an issue with my BIOS where i can’t change a thing in it and after several tries on installing different Linux distributions, it keeps failing to boot after the asked reboot at the end of the installation.
I can’t find the CMOS battery on my motherboard to hard reset the computer to factory mode, and I’m a bit ashamed lol !
If anyone can help me, i’ll take it ! Thanks in advance !
Это хороший вопрос?
Оценка 1
1 Комментарий:
Hello friend, did you find the solution? I have the same problem.
из
Добавить комментарий
2 Ответов
When the ACER logo appears, press and hold ‘‘Alt+F10’’ until screen changes. Hopefully you won’t need to dig for the battery.
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
It doesn’t work at all ! This combination of keys don’t make a thing and I can’t edit anything other than the date / hours + the user password on the Bios, the others are grey
из
Then this seems to be an 1-way. Try to find a trustwotrhy disassembly guide for your acer. Blueprints are hard to find normally, so youtube might be the best choice.
из
That's why I posted here, I didn't find any blueprints or videos with my computer in two days lol !
из
These Acer "Cloudbooks" use a capacitor backed CMOS RAM, with a reference BIOS setting stored in NVRAM. If the machine has problems with saving BIOS settings, it is due to a bad primary battery, as it is held with a supercapacitor on these. I do not see a CMOS battery on the motherboard on this laptop.
Оценка 0
Добавьте свой ответ
Odasio будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 514
