Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
199вопросов Показать все
Powers on, lazer moves and adjusts, disk does not spin.
Can the game disk speed be adjusted
Это хороший вопрос?
Оценка -1
2 Комментариев
Can adjustment be made by the two small screws on underside of lazer unit?
из
William give us some more information about what is going on with your PS2. Just wondering exactly what you are trying to achieve...;-)
из
Добавить комментарий
2 Ответов
Выбранное решение
I believe that you are looking at the adjustment for the laser voltage and unless you get a Disk Read Error, they will not work for you. I would check on the power supply to the drive, all the cable connections and the spindle motor itself and see if that is where your error originates. I have some service manual that you can download from here as well as an very informative repair guide right here Hope this helps and good luck to you.
Был ли этот ответ полезен?
Оценка 3
I'd love to see the manuals, but you need to grant me permission! Would you please? I signed up for an account. Thank you in advance.
Оценка 0
Добавьте свой ответ
William Both будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,205
