Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405вопросов Показать все
Battery Is Not Charging
new battery
new charging wire
new charging port
i have voltage in battery connector on motherboard
SMC reset
GPU - switch off
but... no battery charge, no light on charge wire, can't start without battery.
Plug\unplug charger: https://youtu.be/7rnb9v6DNEo
Battery Information:
  Model Information:
  Serial Number: D861015004NDGDL3T
  Manufacturer: SMP
  Device Name: bq20z451
  Pack Lot Code: 0
  PCB Lot Code: 0
  Firmware Version: 2
  Hardware Revision: 00aa
  Cell Revision: 2
  Charge Information:
  Charge Remaining (mAh): 544
  Fully Charged: No
  Charging: No
  Full Charge Capacity (mAh): 7800
  Health Information:
  Cycle Count: 1
  Condition: Normal
  Battery Installed: Yes
  Amperage (mA): -25
  Voltage (mV): 11350
System Power Settings:
  AC Power:
  System Sleep Timer (Minutes): 10
  Disk Sleep Timer (Minutes): 10
  Display Sleep Timer (Minutes): 10
  Wake on AC Change: No
  Wake on Clamshell Open: Yes
  Wake on LAN: Yes
  Current Power Source: Yes
  Display Sleep Uses Dim: Yes
  GPUSwitch: 2
  Hibernate Mode: 3
  PrioritizeNetworkReachabilityOverSleep: 0
  Standby Delay: 4200
  Standby Enabled: 0
  Battery Power:
  Display Sleep Timer (Minutes): 2
  GPUSwitch: 2
  Hibernate Mode: 3
  Reduce Brightness: Yes
  Standby Delay: 4200
  Standby Enabled: 0
Hardware Configuration:
  UPS Installed: No
AC Charger Information:
  Connected: Yes
  Charging: No
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
I’ve just been fixing one of these tonight if theres no light on the charge wire and you’re sure the charger is good its likely a blown u7000 but its worth changing q7030 and q7031 while you’re here.
I replaced a u7000 tonight the tools I used are a MUSTOOL G1200, 858d hot air ‘station’ max heat and low air, soldering iron with 900m-t-s bent tips, leaded solder and fine tips on my multimeter. I have experience with bits of hot air soldering and its at the limit of my abilities and very easy to create a dry joint.
I appreciate this is a long and complex answer but I’d prefer the information to be here for the next guy so they dont get told to repeatedly reset the smc.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Aleksander Aleksandrov будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 148
