Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2692вопросов Показать все
Restore fails at 0% - iTunes error 9 [Error log included]
Hello,
so my iPhone went black and displays now the “restore screen with the restore url”. Rebooting the iPhone leads to a boot loop until the same restore screen shows up.
Now, while trying to restore the device, it never goes past 0% (progress bar on the device), fails and displays an Error code 9 in iTunes.
Using Google, I tried to use 3UTools to restore the device and immediately, when the progress bar on the device appears, can i see in 3Utools that the device is disconnected.
Moreover, I also tried different ports, cables and Windows/Mac pc’s. But nothing did the trick.
I also had a look at the log but can’t read anything helpful from it.
Anyone who knows whats up? Thanks a lot for your time taken!
14:21:39.627 [2540:5890]: restore library built Mar 27 2020 at 14:03:19
2020-07-20 14:21:39.627 [2540:5890]: iTunes: iTunes 12.10.7.3
2020-07-20 14:21:39.627 [2540:5890]: iTunes: Apple Mobile Device version: 1190.100.2.1.0
2020-07-20 14:21:39.627 [2540:5890]: iTunes: Software payload version: 17G68
2020-07-20 14:21:39.627 [2540:5890]: iTunes: Using MobileRestore state machine
[12:22:49.0327] Can't get board config with NULL device map
[12:22:49.0328] =====================================================
[12:22:49.0328] Device info:
[12:22:49.0328] board configuration: (null)
[12:22:49.0328] Board ID: 0x4
[12:22:49.0328] Chip ID: 0x8000
[12:22:49.0328] ECID: 0x77449944E0A
[12:22:49.0328] Serial Number: FFMSH2WJGRYG
[12:22:49.0328] USB Location: 0x40
[12:22:49.0328] USB Name: (null)
[12:22:49.0328] Starting State: Recovery
[12:22:49.0328] Production Fused: YES
[12:22:49.0328]
[12:22:49.0328] Build Info:
[12:22:49.0328] Restore Bundle Path: C:\ProgramData\Apple Computer\iTunes\iPhone Temporary Files
[12:22:49.0333] requested restore behavior: Update
[12:22:49.0333] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: searching for variant Update (0 recovery)
[12:22:49.0337] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[12:22:49.0337] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer Upgrade Install (IPSW)
[12:22:49.0339] Automatically set FormatForLwVM => True and FormatForAPFS => False
[12:22:49.0339] Failed to create recovery OS variant , no recovery variant in options nor restore variant.
[12:22:49.0339] requested restore behavior: Update
[12:22:49.0339] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: variant not specified, will use first variant found for this device in build manifest
[12:22:49.0342] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[12:22:49.0342] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer Erase Install (IPSW)
[12:22:49.0342] no recovery OS variant found in BuildManifest.plist
[12:22:49.0342] No recovery variant found in bundle, continue without recovery OS installation.
[12:22:49.0343] Changing state from '(null)' to 'Restoring'
[12:22:49.0345] requested restore behavior: Update
[12:22:49.0345] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: searching for variant Update (0 recovery)
[12:22:49.0348] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[12:22:49.0348] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer Upgrade Install (IPSW)
[12:22:49.0350] amai: AMAuthInstallBundleFDRSupported: FDR is supported for this device
[12:22:49.0350] no override trust object found
[12:22:49.0350] requested restore behavior: Update
[12:22:49.0350] requested variant: Update
[12:22:49.0350] personalizing: <AMAuthInstall 00000198771D7C10>{ap=(personalize=YES n71ap ecid=0x77449944e0a, chipid=0x8000, boardid=0x4, isProduction=YES, EPRO=YES, isSecure=YES, ESEC=YES, img4=YES, demotionPolicy=, baaCert=NO, nonce=0x33591dde83568fe160638773abd4e392f653300a, sepNonce=0x79dd5cb9851a1afb75a38ccffc7889b75df1bafe), bp=(personalize=YES), UserAuth=NO, iTunes=YES, server="http://gs.apple.com:80", locale=en_US, version="libauthinstall_Win-698.100.9.100.1", platform=win/10.0(18363) }
[12:22:49.0350] amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes
[12:22:49.0356] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreLogo to Manifest to personalize later
[12:22:49.0357] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreDeviceTree to Manifest to personalize later
[12:22:49.0496] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreKernelCache to Manifest to personalize later
[12:22:49.0746] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreRamDisk to Manifest to personalize later
[12:22:49.0748] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBEC to Manifest to personalize later
[12:22:49.0750] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBSS to Manifest to personalize later
[12:22:49.0790] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting KernelCache to Manifest to personalize later
[12:22:49.0790] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftap to Manifest to personalize later
[12:22:49.0790] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfta to Manifest to personalize later
[12:22:49.0790] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftsp to Manifest to personalize later
[12:22:49.0790] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfts to Manifest to personalize later
[12:22:49.0790] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting OS to Manifest to personalize later
[12:22:49.0791] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LLB to Manifest to personalize later
[12:22:49.0791] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AppleLogo to Manifest to personalize later
[12:22:49.0792] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging1 to Manifest to personalize later
[12:22:49.0800] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SEP to Manifest to personalize later
[12:22:49.0802] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AOP to Manifest to personalize later
[12:22:49.0803] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryFull to Manifest to personalize later
[12:22:49.0804] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreTrustCache to Manifest to personalize later
[12:22:49.0807] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting StaticTrustCache to Manifest to personalize later
[12:22:49.0808] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryPlugin to Manifest to personalize later
[12:22:49.0811] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging0 to Manifest to personalize later
[12:22:49.0812] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow1 to Manifest to personalize later
[12:22:49.0831] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreSEP to Manifest to personalize later
[12:22:49.0832] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow0 to Manifest to personalize later
[12:22:49.0834] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RecoveryMode to Manifest to personalize later
[12:22:49.0835] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting DeviceTree to Manifest to personalize later
[12:22:49.0836] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBoot to Manifest to personalize later
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is True
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreLogo" Digest = "<CFData 000001987AD504C0 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x2ee1a1f896cfa900699958dc50f5073228deb243}"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreDeviceTree" Digest = "<CFData 000001987AD50520 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xee94ff99e0436e57cf5f68747e4740849194dd9b}"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreKernelCache" Digest = "<CFData 000001987AD4FE60 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x0cc2c91e540243a91408e19a6f5b4f87da51acbf}"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreRamDisk" Digest = "<CFData 000001987AD50280 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xab6833bb89eb6c1d167f2a004494d6d6cbc7a4d1}"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "OSRamdisk" not part of manifest, skipping
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBEC" Digest = "<CFData 000001987AD50160 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xf4642ae65109cc8baacf19e44b2c81d33d0d85fd}"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 000001987AD503A0 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x990781cbd699edabb89377e79ce5d75c56c957d7}"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "KernelCache" Digest = "<CFData 000001987AD50220 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x4149c55bc47327ea5ba927bbd17e3fe3273d9a6a}"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "ftap"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "rfta"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "ftsp"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "rfts"
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Diags" not part of manifest, skipping
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "CFELoader" not part of manifest, skipping
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "RBM" not part of manifest, skipping
[12:22:49.0836] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PHLEET" not part of manifest, skipping
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PERTOS" not part of manifest, skipping
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PEHammer" not part of manifest, skipping
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Alamo" not part of manifest, skipping
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "OS"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 000001987AD51720 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x40f9d8b2675c2f3247e4189ce1c1465f442aa821}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AppleLogo" Digest = "<CFData 000001987AD51780 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x35728d7d36996651ab3bd20f78dec283ec33116d}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging1" Digest = "<CFData 000001987AD50F40 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xb5243a45f3b308b46684656d802b7ebd609abd39}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "SEP" Digest = "<CFData 000001987AD50FA0 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x0c629f63376698081d96fe2c153605d720a88b83}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AOP" Digest = "<CFData 000001987AD50340 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x9accf72af4795b5b3fe24192037bb5f07e386769}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryFull" Digest = "<CFData 000001987AD51420 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xff7e8226a189dbb541bae5e9b7e233885abc18df}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreTrustCache" Digest = "<CFData 000001987AD50760 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x15d3aff46b144f42396f8049b1e013713ad91780}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "StaticTrustCache" Digest = "<CFData 000001987AD51060 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xf81be0a38d140143eb9723a1fedffab834f23451}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryPlugin" Digest = "<CFData 000001987AD514E0 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xe3441dd2cb7a00f2c53c0182a9166d420d5aeffb}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging0" Digest = "<CFData 000001987AD50E80 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xb886f2bf88600583a807e9fd63b9ad94bf5ae078}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow1" Digest = "<CFData 000001987AD510C0 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xe3182e2be9464fe6dd5c7e2ef3fdf2487b0c7c3e}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreSEP" Digest = "<CFData 000001987AD50100 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x44e840b5bfa7eb20bc4318df573e849684187fab}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow0" Digest = "<CFData 000001987AD51840 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x7306adbc7f02d3638be62647919f6cd2a3a2cabf}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RecoveryMode" Digest = "<CFData 000001987AD517E0 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xbd6b3be2cdbb6dfb84cfca90c667a80f8d7437dd}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "DeviceTree" Digest = "<CFData 000001987AD50DC0 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xa9981bb030f990eecf45e2f186a377983683395f}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBoot" Digest = "<CFData 000001987AD51480 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0xaff8567846ee3460f2075c81b35681d80248d7c7}"
[12:22:49.0837] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 000001987BC0AA90 [00007FFD8D9450F0]>{length = 20, capacity = 20, bytes = 0x43dc2eb75535f82a0abb3b50d94325cc39ab7689}
[12:22:49.0839] amai: AMAuthInstallRequestSendSync: SSO function returned NULL and no SSO token was provided, SSO disabled.
[12:22:49.0840] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Lars/AppData/Local/Temp/PerD92C.tmp/amai/debug/tss-request.plist
[12:22:49.0840] amai: tss_submit_job_with_retry: TSS Connection attempt 1 of 3. (Will retry if TSS_ERR_SERVER_NOT_REACHABLE.)
[12:22:50.0152] amai: tss_submit_job: HttpQueryInfo returned 200
[12:22:50.0158] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0)
[12:22:50.0160] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Lars/AppData/Local/Temp/PerD92C.tmp/amai/debug/tss-response.plist
[12:22:50.0378] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "OSRamdisk"
[12:22:50.0394] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "ftap" does not require personalization; skipping it
[12:22:50.0394] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "rfta" does not require personalization; skipping it
[12:22:50.0394] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "ftsp" does not require personalization; skipping it
[12:22:50.0394] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "rfts" does not require personalization; skipping it
[12:22:50.0394] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags"
[12:22:50.0394] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "CFELoader"
[12:22:50.0394] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "RBM"
[12:22:50.0394] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "PHLEET"
[12:22:50.0394] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "PERTOS"
[12:22:50.0394] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "PEHammer"
[12:22:50.0394] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Alamo"
[12:22:50.0394] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "OS" does not require personalization; skipping it
[12:22:51.0975] AMDeviceIoControl: GetOverlappedResult failed
[12:22:51.0975] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:22:51.0975] USBControlTransfer: error 2, usbd status 00000000
[12:22:51.0975] command device request for 'getenv ota-uuid' failed: 2009
[12:22:51.0975] Failed to copy env variable, error:2009
[12:22:51.0977] interface has 1 endpoints, file pipe = 1
[12:22:51.0977]
[12:22:51.0979] iBoot build-version = iBoot-4076.30.43
[12:22:51.0982] iBoot build-style = RELEASE
[12:22:51.0984] unable to open device_map.txt: No such file or directory
[12:22:51.0984] found device map entry for 0x00008000 0x00000004 0x00000001. boardConfig=n71ap platform=s8000
[12:22:51.0984] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[12:22:51.0984] requested restore behavior: Update
[12:22:51.0987] requested restore behavior: Update
[12:22:51.0990] unable to open device_map.txt: No such file or directory
[12:22:51.0990] found device map entry for 0x00008000 0x00000004 0x00000001. boardConfig=n71ap platform=s8000
[12:22:51.0990] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[12:22:51.0993] AMDeviceIoControl: GetOverlappedResult failed
[12:22:51.0994] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:22:52.0496] AMDeviceIoControl: GetOverlappedResult failed
[12:22:52.0497] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:22:53.0000] AMDeviceIoControl: GetOverlappedResult failed
[12:22:53.0000] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:22:53.0502] USBControlTransfer: error 2, usbd status 00000000
[12:22:53.0502] command device request for 'getenv radio-error' failed: 2009
[12:22:53.0502] radio-error not set
[12:22:53.0503] unable to open device_map.txt: No such file or directory
[12:22:53.0504] <Recovery Mode Device 000001987A7BB100>: production fused device
[12:22:53.0505] unable to open device_map.txt: No such file or directory
[12:22:53.0505] found device map entry for 0x00008000 0x00000004 0x00000001. boardConfig=n71ap platform=s8000
[12:22:53.0505] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[12:22:53.0505] requested restore behavior: Update
[12:22:53.0509] requested restore behavior: Update
[12:22:53.0511] <Recovery Mode Device 000001987A7BB100>: operation 4 progress -1
[12:22:53.0519] bootstrapping restore with iBEC
[12:22:53.0519] requested restore behavior: Update
[12:22:53.0523] Max file size is: 536870912
[12:22:53.0523] sending file: C:\Users\Lars\AppData\Local\Temp\PerD92C.tmp\Firmware\dfu\iBEC_iBEC.n71.RELEASE.img4
[12:22:53.0540] <Recovery Mode Device 000001987A7BB100>: operation 31 progress -1
[12:22:54.0540] <Recovery Mode Device 000001987A7BB100>: Recovery mode succeeded
[12:22:54.0540] Finished Recovery Restore Phase: Successful
[12:22:54.0638] Recovery mode device disconnected
[12:22:54.0638] Device removed when in state Restoring, moving device to transition state
[12:22:54.0638] Changing state from 'Restoring' to 'Transitioning'
[12:22:54.0638] Creating timer to monitor transition
[12:22:54.0638] Creating a timer for 10 minutes
[12:22:58.0643] Recovery mode device connected
[12:22:58.0643] Transitioning device returned, continuing restore.
[12:22:58.0643] Canceling timer
[12:22:58.0643] Changing state from 'Transitioning' to 'Restoring'
[12:22:58.0644] requested restore behavior: Update
[12:22:58.0644] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: searching for variant Update (0 recovery)
[12:22:58.0650] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[12:22:58.0650] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer Upgrade Install (IPSW)
[12:22:58.0651] amai: AMAuthInstallBundleFDRSupported: FDR is supported for this device
[12:22:58.0651] no override trust object found
[12:22:58.0651] requested restore behavior: Update
[12:22:58.0651] requested variant: Update
[12:22:58.0651] personalizing: <AMAuthInstall 00000198771D7DC0>{ap=(personalize=YES n71ap ecid=0x77449944e0a, chipid=0x8000, boardid=0x4, isProduction=YES, EPRO=YES, isSecure=YES, ESEC=YES, img4=YES, demotionPolicy=, baaCert=NO, nonce=0x33591dde83568fe160638773abd4e392f653300a, sepNonce=0x79dd5cb9851a1afb75a38ccffc7889b75df1bafe), bp=(personalize=YES), UserAuth=NO, iTunes=YES, server="http://gs.apple.com:80", locale=en_US, version="libauthinstall_Win-698.100.9.100.1", platform=win/10.0(18363) }
[12:22:58.0651] amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreLogo to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreDeviceTree to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreKernelCache to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreRamDisk to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBEC to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBSS to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting KernelCache to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftap to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfta to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftsp to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfts to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting OS to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LLB to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AppleLogo to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging1 to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SEP to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AOP to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryFull to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreTrustCache to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting StaticTrustCache to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryPlugin to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging0 to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow1 to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreSEP to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow0 to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RecoveryMode to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting DeviceTree to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBoot to Manifest to personalize later
[12:22:58.0655] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False
[12:22:58.0655] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "OSRamdisk" not part of manifest, skipping
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBSS"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "ftap" entry
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "rfta" entry
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "ftsp" entry
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "rfts" entry
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Diags" not part of manifest, skipping
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "CFELoader" not part of manifest, skipping
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "RBM" not part of manifest, skipping
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PHLEET" not part of manifest, skipping
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PERTOS" not part of manifest, skipping
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PEHammer" not part of manifest, skipping
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Alamo" not part of manifest, skipping
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "OS" entry
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "LLB"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "SEP"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AOP"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreTrustCache"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "StaticTrustCache"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreSEP"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot"
[12:22:58.0656] amai: _AMAuthInstallBundleCreateServerRequestDictionary: nothing to be done
[12:23:00.0166] AMDeviceIoControl: GetOverlappedResult failed
[12:23:00.0166] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:23:00.0166] USBControlTransfer: error 2, usbd status 00000000
[12:23:00.0166] command device request for 'getenv ota-uuid' failed: 2009
[12:23:00.0166] Failed to copy env variable, error:2009
[12:23:00.0167] interface has 1 endpoints, file pipe = 1
[12:23:00.0167]
[12:23:00.0169] iBoot build-version = iBoot-5540.140.12
[12:23:00.0171] iBoot build-style = RELEASE
[12:23:00.0172] unable to open device_map.txt: No such file or directory
[12:23:00.0172] found device map entry for 0x00008000 0x00000004 0x00000001. boardConfig=n71ap platform=s8000
[12:23:00.0172] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[12:23:00.0172] requested restore behavior: Update
[12:23:00.0174] requested restore behavior: Update
[12:23:00.0175] unable to open device_map.txt: No such file or directory
[12:23:00.0175] found device map entry for 0x00008000 0x00000004 0x00000001. boardConfig=n71ap platform=s8000
[12:23:00.0176] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[12:23:00.0178] AMDeviceIoControl: GetOverlappedResult failed
[12:23:00.0178] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:23:00.0681] AMDeviceIoControl: GetOverlappedResult failed
[12:23:00.0681] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:23:01.0184] AMDeviceIoControl: GetOverlappedResult failed
[12:23:01.0184] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:23:01.0685] USBControlTransfer: error 2, usbd status 00000000
[12:23:01.0685] command device request for 'getenv radio-error' failed: 2009
[12:23:01.0685] radio-error not set
[12:23:01.0685] unable to open device_map.txt: No such file or directory
[12:23:01.0685] <Recovery Mode Device 000001987A7C2B60>: production fused device
[12:23:01.0686] unable to open device_map.txt: No such file or directory
[12:23:01.0686] found device map entry for 0x00008000 0x00000004 0x00000001. boardConfig=n71ap platform=s8000
[12:23:01.0686] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[12:23:01.0686] requested restore behavior: Update
[12:23:01.0687] requested restore behavior: Update
[12:23:01.0689] <Recovery Mode Device 000001987A7C2B60>: operation 4 progress -1
[12:23:01.0695] unable to open device_map.txt: No such file or directory
[12:23:01.0696] found device map entry for 0x00008000 0x00000004 0x00000001. boardConfig=n71ap platform=s8000
[12:23:01.0696] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[12:23:01.0696] requested restore behavior: Update
[12:23:01.0697] requested restore behavior: Update
[12:23:01.0699] requested restore behavior: Update
[12:23:01.0700] requested restore behavior: Update
[12:23:01.0702] <Recovery Mode Device 000001987A7C2B60>: operation 43 progress -1
[12:23:01.0702] requested restore behavior: Update
[12:23:01.0706] Max file size is: 536870912
[12:23:01.0706] sending file: C:\Users\Lars\AppData\Local\Temp\PerD92C.tmp\Firmware\all_flash\RestoreLogo_applelogo@2x~iphone.img4
[12:23:02.0726] No additional boot images found
[12:23:02.0731] amai: AMAuthInstallBundleCopyPersonalizedURLsMatchingType: Found IsLoadedByiBoot: RestoreTrustCache
[12:23:02.0735] Sending RestoreTrustCache to device. (1 of 1)
[12:23:02.0739] Max file size is: 536870912
[12:23:02.0739] sending file: C:\Users\Lars\AppData\Local\Temp\PerD92C.tmp\Firmware\RestoreTrustCache_038-52032-078.dmg.img4
[12:23:02.0746] <Recovery Mode Device 000001987A7C2B60>: operation 5 progress -1
[12:23:02.0746] sending file: C:\Users\Lars\AppData\Local\Temp\PerD92C.tmp\RestoreRamDisk_038-52032-078.img4
[12:23:06.0288] unable to open device_map.txt: No such file or directory
[12:23:06.0288] found device map entry for 0x00008000 0x00000004 0x00000001. boardConfig=n71ap platform=s8000
[12:23:06.0288] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[12:23:06.0291] AMDeviceIoControl: GetOverlappedResult failed
[12:23:06.0291] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:23:06.0794] AMDeviceIoControl: GetOverlappedResult failed
[12:23:06.0794] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:23:07.0297] AMDeviceIoControl: GetOverlappedResult failed
[12:23:07.0297] AMDeviceIoControl: failed, error 2, usbd status 00000000
[12:23:07.0799] USBControlTransfer: error 2, usbd status 00000000
[12:23:07.0799] command device request for 'getenv ramdisk-delay' failed: 2009
[12:23:09.0643] <Recovery Mode Device 000001987A7C2B60>: operation 6 progress -1
[12:23:09.0646] Max file size is: 536870912
[12:23:09.0646] sending file: C:\Users\Lars\AppData\Local\Temp\PerD92C.tmp\Firmware\all_flash\RestoreDeviceTree_DeviceTree.n71ap.img4
[12:23:10.0663] <Recovery Mode Device 000001987A7C2B60>: operation 6 progress -1
[12:23:10.0666] Max file size is: 536870912
[12:23:10.0666] sending file: C:\Users\Lars\AppData\Local\Temp\PerD92C.tmp\Firmware\all_flash\RestoreSEP_sep-firmware.n71.RELEASE.img4
[12:23:10.0766] <Recovery Mode Device 000001987A7C2B60>: operation 7 progress -1
[12:23:10.0768] Max file size is: 536870912
[12:23:10.0768] sending file: C:\Users\Lars\AppData\Local\Temp\PerD92C.tmp\RestoreKernelCache_kernelcache.release.img4
[12:23:11.0396] <Recovery Mode Device 000001987A7C2B60>: operation 8 progress -1
[12:23:11.0396] unable to open device_map.txt: No such file or directory
[12:23:11.0396] found device map entry for 0x00008000 0x00000004 0x00000001. boardConfig=n71ap platform=s8000
[12:23:11.0396] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[12:23:11.0398] No readable value found in kAMRestoreOptionsRestoreNVRAMVariables
[12:23:11.0399] <Recovery Mode Device 000001987A7C2B60>: operation 9 progress -1
[12:23:11.0399] <Recovery Mode Device 000001987A7C2B60>: Recovery mode succeeded
[12:23:11.0399] Finished Recovery Restore Phase: Successful
[12:23:13.0369] Recovery mode device disconnected
[12:23:13.0369] Device removed when in state Restoring, moving device to transition state
[12:23:13.0369] Changing state from 'Restoring' to 'Transitioning'
[12:23:13.0369] Creating timer to monitor transition
[12:23:13.0369] Creating a timer for 10 minutes
[12:23:18.0258] RestoreOS mode device connected
[12:23:18.0258] Transitioning device returned, continuing restore.
[12:23:18.0258] Canceling timer
[12:23:18.0258] Changing state from 'Transitioning' to 'Restoring'
[12:23:18.0261] requested restore behavior: Update
[12:23:18.0261] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: searching for variant Update (0 recovery)
[12:23:18.0265] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[12:23:18.0265] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer Upgrade Install (IPSW)
[12:23:18.0265] amai: AMAuthInstallBundleFDRSupported: FDR is supported for this device
[12:23:18.0265] no override trust object found
[12:23:18.0265] requested restore behavior: Update
[12:23:18.0265] <Restore Device 000001987A7BB100>: operation 45 progress -1
[12:23:18.0265] requested variant: Update
[12:23:18.0265] personalizing: <AMAuthInstall 00000198771D7C10>{ap=(personalize=YES n71ap ecid=0x77449944e0a, chipid=0x8000, boardid=0x4, isProduction=YES, EPRO=YES, isSecure=YES, ESEC=YES, img4=YES, demotionPolicy=, baaCert=NO), bp=(personalize=YES), UserAuth=NO, iTunes=YES, server="http://gs.apple.com:80", locale=en_US, version="libauthinstall_Win-698.100.9.100.1", platform=win/10.0(18363) }
[12:23:18.0266] amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes
[12:23:18.0268] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreLogo to Manifest to personalize later
[12:23:18.0268] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreDeviceTree to Manifest to personalize later
[12:23:18.0268] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreKernelCache to Manifest to personalize later
[12:23:18.0268] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreRamDisk to Manifest to personalize later
[12:23:18.0268] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBEC to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBSS to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting KernelCache to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftap to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfta to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftsp to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfts to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting OS to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LLB to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AppleLogo to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging1 to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SEP to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AOP to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryFull to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreTrustCache to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting StaticTrustCache to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryPlugin to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging0 to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow1 to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreSEP to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow0 to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RecoveryMode to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting DeviceTree to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBoot to Manifest to personalize later
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "OSRamdisk" not part of manifest, skipping
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBSS"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "ftap" entry
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "rfta" entry
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "ftsp" entry
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "rfts" entry
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Diags" not part of manifest, skipping
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "CFELoader" not part of manifest, skipping
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "RBM" not part of manifest, skipping
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PHLEET" not part of manifest, skipping
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PERTOS" not part of manifest, skipping
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PEHammer" not part of manifest, skipping
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Alamo" not part of manifest, skipping
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: skipping "OS" entry
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "LLB"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "SEP"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AOP"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreTrustCache"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "StaticTrustCache"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreSEP"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot"
[12:23:18.0269] amai: _AMAuthInstallBundleCreateServerRequestDictionary: nothing to be done
[12:23:18.0270] requested restore behavior: Update
[12:23:18.0272] overwrite InstallDiags to false
[12:23:18.0276] device did not return saved USB log
[12:23:18.0276] device did not return saved panic log
[12:23:18.0278] connected to service com.apple.mobile.restored
[12:23:18.0278] using protocol version 15
[12:23:18.0282] unable to open device_map.txt: No such file or directory
[12:23:18.0282] board config = n71ap
[12:23:18.0285] no value returned for BootArgs
[12:23:18.0285] _copyDeviceProperty() failed for restore bootargs
[12:23:18.0288] no value returned for MarketingPartNumber
[12:23:18.0289] _copyDeviceProperty() failed for mpn
[12:23:18.0289] requested restore behavior: Update
[12:23:18.0294] value query for 'HardwareModel' returned 'N71AP'
[12:23:18.0295] Can't return padding information since it's not in the Restore.plist, looking in BuildManifest.plist
[12:23:18.0298] requested restore behavior: Update
[12:23:18.0298] Established proxy for device ID 5
[12:23:18.0366] Completed checkpoint id: 0x655
[12:23:18.0368] Started checkpoint id: 0x608
[12:23:18.0369] Completed checkpoint id: 0x608
[12:23:18.0376] <Restore Device 000001987A7BB100>: operation 28 progress -1
[12:23:18.0385] <Restore Device 000001987A7BB100>: operation 58 progress -1
[12:24:04.0984] RestoreOS mode device disconnected
[12:24:04.0984] RestoreOS device removed before restored completed
[12:24:05.0002] recv(4868, 4) failed: connection closed
[12:24:05.0002] unable to read message size: -1
[12:24:05.0002] Failed to receive message from device, might be connection problem with USB host.
[12:24:05.0002] AMRAuthInstallDeletePersonalizedBundle
[12:24:05.0187] <Restore Device 000001987A7BB100>: Restore failed (result = 9)
[12:24:05.0187] Can't send dump_console command since device is not in recovery mode
[12:24:05.0187] Finished RestoreOS Restore Phase: Failed
[12:24:05.0187] State Machine Dump, status:ERROR - [state:Recovery remaining-cycles:0] -> [state:RestoreOS remaining-cycles:0 (current state)]
[12:24:05.0187] Restore completed, status:9
[12:24:05.0187] Restore Checkpoint Fingerprint: 0608.0000
[12:24:05.0187] Failure Description:
[12:24:05.0187] Depth:0 Code:-1 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 9
[12:24:05.0187] Depth:1 Code:9 Error:Failed to receive message from device, might be connection problem with USB host.
[12:24:05.0187] Changing state from 'Restoring' to 'Error'
[12:24:05.0187] State is now set to error: AMRestorePerformRestoreModeRestoreWithError failed with error: 9
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
You’re gonna need someone who specializes in microsoldering. https://www.youtube.com/watch?v=qW0YhcCo...
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Visible Panda будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 68
За всё время: 3,744
