Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1502вопросов Показать все
Cant fully restore Error 1013
I have a iPhone 3gs and every time i try to restore with the latest version of itunes it will go all the way to the end of the restore and say error 1013. i have not messed with the host file or anything. Im just trying to resotre my iphone 3gs to 4.3.5
Это хороший вопрос?
Оценка -1
1 Комментарий
I'm having this same problem, I even bought a new battery and a new sync cable.
I've tried to restore it on 3 different pc's to no avail :(
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
The Hosts issue is reported with iPhone 4 and you have a 3GS. But, anyway it would not hurt to just check your Computer Hosts file to make sure gs.apple.com is not in your Hosts file. Search on your computer for 'Hosts', open with a word processor, make sure gs.apple.com is not there.
A recommended way to fix Error 1013 is to try restoring on another computer. Make sure you have a good USB cable, and use a dedicated USB port (one on the back of computer). Turn off securitiy, anti-virus software.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Nope the Host file is clean. I just cant figure it out with this 3gs. My iphone 4 does fine with the same cord and same usb port. I also restored a iPod touch on the same computer. I have had the phone apart just to see if there was anything loose and nothing. As soon as it goes through the restore process it will say error 1013 and then go into DFU mode. The restore loading bar will go all the way to the end almost completely full except for a little tiny bit and it will never finish. I quit messing with it and one day i picked it up and it was fine. I picked it up and slide to unlock and i could scroll through the pages. Then about an hour later back into DFU mode.
из
Try another computer on another internet network is Apple recomendation. Do that next.
Couldn't hurt to clean the pins in the iPhone dock port with a clean toothbrush and some Isopropyll Alcohol. Try Restore again.
из
Did you try updated it? if that doesn't work, then try using tinyumbrella (google it). then follow the steps on how to kick it out of recovery mode.
Оценка 0
Добавьте свой ответ
Bradley будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 3,327
