Charging paused - temperature too low
I’ve ordered a new NFC wireless charging coil plus the plastic plate that it’s attached to. I hope this fixes it. Does anybody know if it will?
It started happening after I put adhesive under the charging coil to keep it stuck on and also another part of the coil which doesn’t seem to connect to anything. I doubt I damaged the actual board; I hope not, it’s $100 used!!
The other part of the coil I’m referring to:
== Update (07/25/2020) SOLVED ==
Replacing the NFC Charging coil fixed it! Woohoo!
Это хороший вопрос?
