Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342вопросов Показать все
My screen is flickering :(! Help!
Alright so, as you can see in the photo that is how it looks like.
My Mac is from Mid 2010 21.5” with 4 GB RAM, running on High Sierra. I have tried searching for a solution online, but I can’t find anyone, who had the same problem as mine.
What I’ve tried so far:
  • Reboot and redownload everything. (Deleted the whole Mac), and still the flickering is happening and keeps shows up.
  • I’ve tried reset NVRAM and SMC, still did not work.
  • Start up on recovery Mode, still did not work. (Also I pressed down D).
  • Updated newest software.
Symptoms other then the flickering screen:
  • I woke up this morning, and the flickering was gone for like 20 mins, and came back.
  • The computer is heating up a lot.
  • The computer ONLY STARTS UP if I hold the down shift key! If i start up normally, then it freezes halfway through booting/loading. (or opening or whatever you call it)
This confuses me, and I hope someone can help.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Ah! Confusion!
Lets step back for a sec … Your system has two graphics services! One within the Intel CPU its self (Intel HD Graphics) and a second discreet GPU MXM board: ATI (AMD) Radeon HD 4670 or Radeon HD 5670.
So what happening here is you are jumping between them! When you startup pressing the Shift (⇧) key you are using the Intel HD graphics as the AMD GPU board drivers are not loaded.
Reference: Mac startup key combinations
Where does that leave us? You have a failed GPU board which will need to be replaced, this is not a software issue!
iMac Intel 21.5" EMC 2389 GPU Card Replacement
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
rebin_911 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 49
