Which bolts go where
The power steering pump the belt pulleys the tensioners the water pump the thermostat all have been removed I know where they all go I just can't figure out which screws go where for 98 Nissan quest
Это хороший вопрос?
Это хороший вопрос?
Hi @ladykayak1966 ,
Here’s the 1998 Nissan Quest Service Repair Manual
Click on Contents: Steering.
When you have the file on the screen (select Fullscreen to make it easier to see and use) go to p.ST-22 onwards to view how to disassemble/reassemble the power steering pump.
The others sections of the manual, e.g. engine lubrication & cooling systems and engine mechanical will help you with the others.
There is a download icon at the right side end of the document header bar if you want to download it to your computer
Hopefully this is of some help.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 63
