(Solved) Why Is my Front Facing camera not working after a lcd repair?
When replacing screen with an OEM Service pack from a reputable supplier, I have lost the functionality of my selfie camera.While testing in old screen, selfie camera works. I have double checked my supplier and found that this screen only works on non-verizon models. This OEM Service pack comes with a camera not compatible with the verizon main-board. Solution is to get a screen that is compatible which isnβt available at time of posting.
ΠΡΠΎ Ρ ΠΎΡΠΎΡΠΈΠΉ Π²ΠΎΠΏΡΠΎΡ?
6 ΠΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΠ΅Π²
what if i donβt have the original camera ? is ther a way to since the new camera and motherboards ?
ΠΈΠ· julio kilgore
I had a similarly problem. When i changed the screen, the cΓ’mera loose the ability to get focused. Is always a problem to replace it?
ΠΈΠ· eduardoamaralmp
had the same exact issue thanks to you i was able to get it working again! i just took the orinal camera and sensor from the broken screen and replaced it with the one that came with the replacement screen. worked like a charm :-)
ΠΈΠ· Kelvin C
I replaced mine camera worked fine until I had to update my phone now nothing
ΠΈΠ· Elizabeth Ellison
It can be fixed even if you dont have the old screen for front camera vaibhav.kapoor@yahoo.com
ΠΈΠ· Vaibhav kapoor
ΠΠΎΠΊΠ°Π·Π°ΡΡ 1 Π±ΠΎΠ»ΡΡΠ΅ ΠΊΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΠ΅Π²
