Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
163вопросов Показать все
Can I fix the pcb for the right analog stick?
I tried to replace the module for the right analog stick, and now it constantly aims right, even when there is no module connected. I believe this is a problem on the pcb itself and was hoping to receive assistance. Thanks in advance.
Это хороший вопрос?
Оценка 1
1 Комментарий:
James Fox post some pictures of your PCB (both sides and the repair attempt) with your QUESTION.
Adding images to an existing question
из
Добавить комментарий
1 ответ
You probably rip some traces and need to run some jumper wire
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
James Fox будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 397
