Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573вопросов Показать все
keyboard typing extra characters
i have an iMac 27" and it is working fine but since a few days the keyboard is acting very weird. While typing the keys its typing extra characters and specifically when i press m its takes the cursor and places before m. When used a regular windows keyboard with wire it works fine but when i type with the magic keyboard its acts weird. Need your help to understand the issues.”
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Hello, you may need to take apart the Apple keyboard and clean it, while making sure no liquid has entered in on anything. I’ve had the same issue with a razor gaming keyboard and it ended up having some Debris in it, that made two keys off set. Once cleaned it’s worked great!
Был ли этот ответ полезен?
Оценка 0
Review this teardown Magic Keyboard Teardown
Sadly, Apple uses rivets to hold the sandwich together so if you had a spill its hard to clean the switches. Popping off the keycaps is all you can do to try to get the junk out which is interfering with the scissor mechanism.
Оценка 0
Добавьте свой ответ
Amit Ostwal будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 362
