A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542вопросов Показать все
New build, reboot and select new media
Motherboard: ASUS AM4 TUF Gaming X570-Plus (Wi-Fi) ATX Motherboard
Graphics card: nvidia 1080 (will be replacing when 3080 is in stock)
Proccessor: AMD RYZEN 7 3700X 8-Core 3.6 GHz
Ram: 4'x CORSAIR Vengeance RGB Pro 16GB
Power supply: 750W Corsair
Storage: 2x 500GB, 1x 3TB
This is my first computer I've built, I'm have a problem with the the computer saying it has no boot media, the 2 500GB drives where both from my old computer I had and it worked perfectly fine. I've tried clear the key management, playing with what Hard drive it was booting off, tried moving cables.
Это хороший вопрос?
Оценка 0
2 Комментариев:
What OS are you installing on it? Does it not detect it in the BiOS or in the OS install screen?
из
I'm running windows and I believe it registers
из
Добавить комментарий
1 ответ
It sounds like you need to create or buy an installation media.
The link I am providing will allow you to create a USB install drive from another computer. Once that is created it will allow you to install Windows 10. Although, because this is a new build, you may not be able to use the key you had from the previous computer. Windows 10 will still work, but it will tell you that it is not genuine until you either buy a new activation key, or sometimes you can contact them and they'll allow you to reactivate the key from the previous computer. (Sometimes)
Also, installing Windows will wipe whatever is on that drive, so please make sure you install in on the intended blank drive.
https://support.microsoft.com/en-us/help...
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
I tried the USB with the link you provided but It didn't work so I believe I did it incorrectly
из
Its currently taking me in a infinite loop of copying windows 10 to one of my drives
из
they changed the process a little since the last time I created an install drive. When you copied the Windows ISO to the drive, did you burn it or did you copy it?
из
Добавьте свой ответ
Issahia Farley будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 80
