Phantom touches - touch screen
Hi,
I have a Samsung Chromebook book Pro and it suffers from phantom touches when I have the touchscreen enabled. It has suffered from this issue for ages. However I've just disabled the touch screen as I didn't really use it that often.
However I now want to use the touch screen to try and take notes. I would like some guidance to a fix. As from what I have seen it is a hardware issue. The touch screen worked for ages and then it gradually got worse and worse.
I have tried factory resets in the past
If it is a screen replacement where can I source one In the UK?
Thank you! Some help would be much appreciated!
Paddy
Это хороший вопрос?
Счет 1
1 Комментарий:
I think I have a similar problem. My screen intermittently jiggles, shakes, zooms in/out, and opens closes windows without input. I can usually stop this occurring by moving/adjusting the screen angle. I don't think it's a screen issue I'm inclined to think it is a short or pinched cable.
из
Добавить комментарий
