PSU power on signal
I’m trying to to use the iMacs PSU to build a mini-itx hackintosh.
Is it possible to use the power-on button in the iMac and then somehow connect it to the PSUs pin12, which should be the power-on signal?
PSU pin-out: Power Supply (PSU) pin-out diagram
I have removed the main board to make room for a display converter board to use the screen as a monitor, so I need to connect the power-on button directly to the PSU if possible.
Это хороший вопрос?
