The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
New battery not recognised in MacBook Pro 13(early 2015)
Hello All
I’ve recently purchased and fitted a “new” battery bought from iFixit. Basically, my Mac doesn’t recognise the battery, so either the battery is faulty or there is some setting I need to change? As iFixit don’t offer support, I’m hoping I can get a solution here, before contacting my credit card provider for a refund. iFixit really shouldn’t offer a “solution” if the Apple software and hardware environment doesn’t support it.
It’s a Macbook Pro A1502 13” Retina (Early2015). What I’ve done so far:
  • Disconnected and reconnected the battery (This did resolve a non-responsive keyboard and trackpad).
  • Reset SMC,3 times
  • Run First Aid on Disk Utility
 Other observation/issues:
  •  Unit is powered with mains power cable when this is removed the unit switched off.
  • The charger shows amber light.
  • The unit runs VERY slowly
  • Bluetooth and Wi-Fi are not available as options. Luckily I’m able to plug in an ethernet connector
  • There is no battery indicator on the desktop.
Any insights or suggestion would be great.
Thanks
Symon
Это хороший вопрос?
Счет 1
3 Комментариев
@sdm72 - Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Having something more tangible will get you working quicker! Having this will tell me whats happening.
As far as iFixit They fully support their products. I've bought a fair amount of tools and parts from them.
Batteries are tricky! As you could have gotten a bad one. IF thats the case here you should be able to get one quite fast from them.
из
Thanks Dan.
Please see an update on the state of play.
observations / issues:
Unit is powered by Magsafe adaptor that displays the amber light, which it also does when the battery is disconnected.
The unit runs VERY slowly indeed.
Bluetooth and Wi-Fi are not available as options, however will connect to ethernet with USB adaptor
The Sysinfo shows zero’s or no entries.
I had downloaded two battery programs( Coconut and Battery Health from App store) ( More than once) however they will not start. The programs do work as I’ve tested on my other MAC. All other programs work albeit very slowly.
из
@sdm72 - "Unit is powered by Magsafe adaptor that displays the amber light, ''which it also does when the battery is disconnected."' That tells me your magSafe charger is bad! As it shouldn't be lit if disconnected!
Your system is slow as its in CPU Safe Mode as SMC is detecting a major defect! We need to resolve the battery issue first to then look deeper into this.
At this point I think you have a bad battery here as well. CoconutBattery should load up, I've never seen it fail me unless ... you are running an old version of macOS that the version of CoconutBattery is not designed to run on.
из
Добавить комментарий
4 Ответов
Выбранное решение
I had a similar issue with a late 2013 MacBook Pro retina. In the end what worked for me was:
  1. Disconnect the battery connector
  2. Connect the charger and turn on the Macbook
  3. Turn it off and disconnect the charger
  4. Connect the battery connector again
The next time I turned on the MacBook it recognized the iFixit battery. It was almost like it had to be powered on without any battery to then notice when the new battery was added. Funny enough, back in the day, I used to use this trick with 133MHz SDRAM when the PC wasn’t detecting a module.
Be very careful while turning on the MacBook with the lid open, you don’t want to short-circuit anything!
Был ли этот ответ полезен?
Счет 14
10 Комментариев:
this solved it for me, thanks dude. I was going crazy trying to figure it out thinking my laptop was doomed
из
Solved it for me as well. Have a late 2013 macbook pro retina.
After swapping the battery for a third party one, icon and system prefs were gone. Doing this brought everything back.
Thanks a million!
из
Absolute legend
из
I realy Thank you
You saved my Day
It worked
из
Thank you, thank you very much. It has worked for me. Macbook Air 13" mid-2011.
You really has saved my day!!!
из
Показать ещё 5 комментариев
Many newer laptops with mini chargers absolutely need the battery to provide extra power when the cpu clocks up. Also most units now use both an age & genuine check. If the battery wasn’t “fresh”, you’ll have all the problems you described. It’s not the actual battery cells that are bad, probably bad data on the “on battery computer”. Batteries aren’t dumb anymore, they have their own data and safety processor.
I used to rebuild batteries & reprogram them as certain computers could never recognize a “replacement”.
I know there are some battery utilities out there to update the date & recalibrate the unit. Probably not an option, but there may be one out there.
Счет 1
1 Комментарий:
appreciated but u also visit this web to get more and relevant solution https://dart-board.net/store/
из
With Apple computers, if the battery is bad or not recognized the computer will be very slow. so that is normal.
Unfortunately, I have had my fair share of bad batteries from iFixit. They have a great return policy so you won’t have to dispute it with your bank. just let them know your issue with the battery and they will either refund you or send you a new one.
With Apple computers, it should recognize the battery right away when you plug a new one in without having to do any reprogramming. So being that it doesn’t recognize it. It sounds like there is either something wrong with the battery or the main logic board. but it’s more likely to have an issue with the battery.
Счет 1
2 Комментариев:
Yeah I agree. There are some super pricey devices that check and refresh batteries. All they really do is reprogram the data to current. But that means an employee & some pricey hardware. It is what it is.
из
@dshelgren - When you go shopping for eggs, you do make the effort to check each egg to be sure you don't get a bad one. Of course the hen or the farmer through in one bad one just to mess you up ;-}
Sadly batteries are very similar! Things happen! Either in the manufacturing process that wasn't caught or during shipping.
Now batteries sold on some of the marketplaces are cheap rebuilds, I've seen some real horror stories! These fly-by-night outfits disappear so you can't get your money or a good replacement.
из
Oh sh*t it worked!! 2020 Macbook Pro, new battery from 3rd party. Powered down, disconnected charger, disconnected battery connector, powered on, then powered off, reconnected battery connector, turned back on and violá. Worked like a charm. Took 2 attempts I think I didn’t connect the battery connector correctly the first time. Many thanks.
Счет 0
Добавьте свой ответ
symonmeikle буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 16
За последние 30 дней: 120
За всё время: 9,060
