Strange power button problem (works partially).
Hi
I have a strange problem with the power button. Not responding when I want to turn on the macbook. With the system running, it works and allows you to go into sleep mode, but you can't come back from it. The only thing that helps then is removing the battery and inserting magsafe (which starts the macbook).
Macbook has never been flooded.
Это хороший вопрос?
2 Комментариев
I'm suspecting your battery is no its last legs
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из Dan
The battery is almost new, so I don't think it's causing problems.
I noticed a strange thing. I have uploaded a fresh system. while installing the update, the macbook reset and beep once long.
I found information that the mac is making a long beep when we press the power button while updating the firmware.
из Grzegorz Hexel
