This HD video recorder contains an excellent camera mode that records and detachable stereo microphone capsules.
7вопросов Показать все
Why does my Q8 Camcoder suddenly turn off during my recording?
My Q8 Camcoder sometimes turn off when I was recording. I checked the battery and SD card spaces they all look perfectly fine. It is not a problem caused by battery and storage space. I could not find the reason why the camera suddenly blackout during my recording process which makes me very frustrated, and I cannot make a complete recording since I can not predict when it’s going to be dead.
Это хороший вопрос?
Оценка 1
1 Комментарий:
I try recoding my band and the camera shuts off after (Approximately) 45 minutes. I can't even film a whole set. Very disappointed in this camera. Would not recommend anyone to buy this camera at this point.
из
Добавить комментарий
1 ответ
This is due to a limitation of the .mov file, which the Q8 and Q4 use to record. The maximum size a .mov file can be is 4GB. Once this limit is reached while recording with the Zoom camcorder, it will begin a new file to continue further recording , if this does not happen check in the settings to see if you can continue recording after it has reached the 4gb file size.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
What settings? There is nothing in the settings menu to adjust this that I can see.
из
Добавьте свой ответ
Dailin Zeng будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 594
