Why does my brake pedal go to the floor when the engine is running but
when the engine is running, my brake pedal goes to the floor. when engine is off, I can pump up the brakes somewhat. I have changed the master cylinder and there is no fluid leak. Could the problem be with the power assist boost, or is there something else that could be the issue?
Это хороший вопрос?
2 Комментариев
My brake pedal go to the floor it stop the car but with the pedal tolow
из Jose Fernandez
Hi I have a 2004 dodge dakota,Replaced (rear break lines rear rotors ,calipers,pads front calipers ,pads ,master cylinder, and brake booster.Bled out all air have a good hard up top pedal when truck is off .As soon as started pedal goes to the floor ? Why why ? Also the new booster check valve has three holes the old one only two.??
из Tom Brunet
