Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
120вопросов Показать все
Apple Watch freezing every time
My Apple Watch series 4 freezing every time , sometimes works perfectly for couple of hours
I’m unpairing repairing every time
hard reset can’t resolve this issue
I tried with several iPhones & updated Watch os
still same sometimes Digital Crown stopped working
screen is always freezing how can I fix this
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
That sounds like a logic board issue, your best bet may be to try swapping in some parts but if that doesn’t work you might have to buy a new watch.
Был ли этот ответ полезен?
Оценка 0
4 Комментариев:
Which parts needs to be swap
из
everything except the logic board
из
I replaced the screen & new battery still problems persisting
из
said everything, not just screen and batt
из
If you are still having issues, try this.
  1. Force restart the device (hold the crown and power button)
  2. Once the device turns off, let go of both buttons. When the apple logo appears, hold the power button (lower right one) until the erase all content option appears
  3. Follow the prompts and allow the device to reset.
  4. Pair the device again
Hope this helps!!
Оценка 0
1 Комментарий:
I tried several times
It was working for week then goes to freezing again
из
Добавьте свой ответ
Shaheen Sultana будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 159
