Replacing Qualcomm AX500 Killer Wifi
This Qualcomm AX500 Wifi does not work for me using Linux and I wanted to replace it with a Intel Wireless-AC 9260 (M.2 (PCIe)). However on the top left corner there is the card reader (green) where the Wifi module used to be.
Any change replacing the Wifi (red)? Is is soldered to the board or still an M.2 PCI card?
Это хороший вопрос?
3 Комментариев
@haa29 I am old so I confuse easy? You want to change the WiFi module on what device? What are you comparing this to? However on the top left corner there is the card reader (red) where the Wifi module used to be.
Any change replacing the Wifi (green)? Is is soldered to the board or still an M.2 PCI card?
из oldturkey03
Apparently this thread is for a Dell XPS 15 9500. And when you do an Internet search for replacing the Wifi module on a Dell XPS 15 it will be located in top left. How you expect to answer this questing if you do not know all this? (Wifi is red and card reader green)
из Andreas
@haa29 no reason to become testy or wondering how I was going to answer. Obviously you are the one that has the motherboard and laptop right there so all you needed was to clarify what is on your board to see if you can change the WiFi board.
из oldturkey03
