Repair guides and support for the first generation of Sony's RX100 high-end compact camera with a 20.2 MP sensor. The Sony Cyber-shot DSC-RX100 was released in June 2012.
30вопросов Показать все
Sony RX100 II M2 - LCD Goes Blank When Tilted - How to repair it?
Hi everyone,
Video: https://www.youtube.com/watch?v=mgEYbha1...
Is there something I can do? Shall I open it up and check cable connections? Has anybody come across similar issue?
Has the magnet got anything to do with it in the upper right corner of the screen?
Many thanks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
@mitbrille not sure about the magnet but I would try to set the LCD brightness.
Go to 1. MENU 1 [LCD Brightness] desired mode and set it to Manual. See if that changes anything. If not then it is possible that this is related to the light sensor or bad ribbon cable. Check this video at the 6:05 mark to see the sensor.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
X.Y. будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 189
