2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274вопросов Показать все
MacBook Pro A1398 no keyboard and trackpad
hello,
so first the macbook didnt have backlight, i have replaced the fuse and LCD connector because they were corroded, now the screen works perfectly,
but the problem is the keyboard and touchpad are not working only the power button is working i can turn the macbook on and off,
before i order a keyboard and trackpad i want to be sure its not a motherboard problem,
can anyone help?
Это хороший вопрос?
Оценка 0
2 Комментариев:
Does an external USB keyboard & mouse work?
из
yes that works
из
Добавить комментарий
1 ответ
I don’t think you have a keyboard or trackpad issue. I’m suspecting the logic board still has issues. Rarely does both fail full out. Lets see if we see more corrosion on the board. If you haven’t already taken the logic board out I would do that following this guide MacBook Pro 15" Retina Display Early 2013 Logic Board Replacement Take some nice tight pics of any area that looks off and post them here for us to see Adding images to an existing question.
MacBook Pro 15" Retina Display Early 2013 Logic Board Изображение
Инструкция
Сложность:
Сложно
1 - 4 hours
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
jozef horvath будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 165
