Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
My Controller Will Not Connect To My Xbox
I have tried updating it and its completely updated, and nothing that I can see internally is wrong like nothing looks water damaged, nothing looks bridged and nothing looks burnt but it will not connect. It will flash for a few sec then I tried using the sync button and it connected for about 4 sec but it seemed to disconnect when I touched a button but it would connect if I didn’t press anything after. I just want to know if this is a board problem or something else and if it is a board problem what board do I need to replace?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If your Xbox One Wireless Controller is not syncing or connecting to your Xbox console, see the Xbox One Wireless Controller Won’t Connect to Console problem page for possible causes and solutions.
Have you plugged the controller into the console via USB to manually sync?
Does it stay synced after you remove the cable or lose sync?
Have you got another controller to see if it happens with all controllers or just one?
Further information is needed to help you with this, please provide as much info as possible.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
WilliamNonya буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 495
