Hi @Candy Aaron
What is the model number of the refrigerator?
Can you hear if the evaporator fan inside the freezer compartment is operating?
It will stop when the door is open and start again when it is shut (either door -freezer or refrigerator), so you may be able to hear it that way.
If you can't hear it then there is either a defrost problem or an evaporator fan problem. The fan should operate as long as the compressor motor is running.
A defrost problem means that ice builds up on the evaporator unit and eventually ices up the fan which stops it from working. It is the evaporator fan that blows the cold air from the freezer compartment into the refrigerator compartment to cool it down to the set temperature.
The causes of a defrost problem could be either a faulty defrost heater, faulty defrost thermostat (or thermistor), blocked drain from the freezer to the evap pan under the compartment or a faulty control board
A fan problem could be a faulty fan or loose fan blade or a faulty control board.
If you can hear it, then it may be an air damper problem
Note: All the above is for a refrigerator model that has only the one evaporator unit and not two i.e. one in the freezer only and not one in the freezer and one in the refrigerator. That’s why knowing the model number helps as it can be other problems for a model with two evaporator units.
Был ли этот ответ полезен?
Проголосовали
Отменить
Счет
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
3 Комментариев
Hi @cjmitchell ,
What is the refrigerator compartment temperature like?
Just wondering how you checked the "coolant" levels as it is a sealed refrigerant system? Do you mean the high/low pressures in the sealed system?
из jayeff
MODEL GSHS6HGDSS. I should have been more specific: the sealed system was checked by an appliance repairman and was fine. The refrigerator temp stays within a few degrees of what it is set on the display (37*).
из Chris Mitchell
Mine is opposite, the fridge set is 37 but actual states 60. The freezer is set for 0 and actual is 0. Any ideas?
из Candy Aaron
