I want to replace the audio cable
The cable needs replacing and after removing the 2 inset phillips head screws I’m stumped! How do I open up the console to replace/repair the cable, which broke right at the grommet?
Это хороший вопрос?
Это хороший вопрос?
Hi @kmalivuk ,
The answer in this link may be of some help.
Senheisser rs120 earphones - does the charging dock wire just pull out
It says :
“There are two screws on the side of the unit that need to be loosened (or removed). After that use an old plastic credit card (or similar) along the edges of the white front panel to pry it loose. You'll then have access to the cable etc.”
Был ли этот ответ полезен?
Thanks Jayeff, the rest is easy after the front panel is off!
Thanks Jayeff - indeed, though I haven't found these screws yet - are they covered by the stand pads of the base station?
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 370
