Дата выхода 25 сентября 2015 г. Модель A1687 / A1634. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
Home button / battery fire
Changed battery on my cousin’s 6s plus ….. it was damaged and actually caught on fire when removing it. I quickly got it out of phone , it appeared not to do too much damage. Some scorching in the left corner around and on headphone jack . I cleaned it up put new battery in , put it back together powered up everything worked EXECPT home button ….. top screen / home button was not on/near battery when it caught on fire … do I need to change charging port / headphone jack assembly….. or something else like change the entire back assembly of the phone . Need some ideas or help on what direction to go
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If you didn’t remove the actual home button I would make sure the connector is seated properly. If it is than you have most likely damaged the flex cable or nudged a tiny component around the connector. If it is a damaged flex you will need to replace the screen.
The charge dock has nothing to do with the home button.
Был ли этот ответ полезен?
Счет 1
Thanks, Chris …..The reason I asked about the port and the surrounding area is , because in reading one of the other posts , talking about the home button , someone mentioned a broken or bad ( in my case melted ) connection causing a continuity problem that affected the home button. …. I’ve removed and reconnected everything multiple times. And when the fire took place the screen and button where 4 feet away, so the fire couldn’t have damaged the cables or connectors. Not to say I might have when I removed them with spudger . Is there anything under the headphone jack orTaptic Engine that could cause this issue? Like a ground wire or a ribbon cable …..any or next idea please
Счет 0
Добавьте свой ответ
Joe Hoy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 95
