The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623вопросов Показать все
Backlight driver replacement without affecting the resistors
PLEASE HELP!!!
A beer spilled on this mac which was immediately wiped off but after some time the mac started getting pretty slow, it runs at top speed, it got to a point that mac OS isn't recognized on the machine, only windows OS boots up. but same SSD works fine on another machine .
After sometime the keyboard light and the screen backlight went off.
I tried to reball the backlight driver chip, which was successful only for the screen backlight for just 24hrs.
Now I attempted to replace the chip but I wasn't successful, a resistor got kicked off in the process, when I searched for it I got to know it was R7753, a 0 ohm resistor.
Can I use a jumper wire to replace this resistor?
And how can I use heat gun in such a way that the resistors won't be affected?
And what type of nozzle can I use for this kind of delicate job?
Is my Koocu SMD rework station 852D+ suitable for this kind of job?
The issues again :
Fan runs at top speed
Mac OS isn't recognized
No backlight for both the keyboard and LCD
R7753 resistor got kicked off
PLEASE HELP!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
@zilicon okay I am going to make a whole bunch of assumptions on here. You have done “reball” before, you checked to make sure that the LED driver IC is still working and did not replace it (you should have) and of course you cleaned everything else properly so as to avoid further corrosion damage and short circuit’s.
The original package for the R7753 is a 0201 size so you know it is small. Yes you can apply a jumper wire instead. Do not use the hot air part of your rework station but actually use the soldering tip for this job. It’ll give you more control of your part and the solder. It does confuse me that you reballed your IC but are not sure about soldering the resistor. If you have not done this kind of work before, it maybe better to send the board out for repair.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thank you @oldturkey03 for your quick response, yes I know how to use the soldering tip for soldering.
Good news is I've found the resistor.
I actually I read in a forum that I can reball the chip. But I'm ready to replace the chip with a new one.
I don't know why the chip did not remain settled on the board, the air from the heat gun displaces the chip from the right spot.
I'll also appreciate your comment on other issues.
Thanks again
из
@zilicon sounds like the hot air is moving the IC around because it needs more top heat and less if any from the sides.
из
Добавьте свой ответ
Jacob будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 95
