Line of business laptops originally sold by IBM and then purchased by Lenovo in 2005. Older models (Pre-XX50) have a WiFi whitelist, so wireless card replacement is not as easy as buying a bulk generic card online.
PCI LAN: Realtek PXE B09 D00
I have a pop-up on my daughter's laptop has this error that pops up and we can't get it off.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Выбранное решение
Check if you see a hard drive present in the BIOS - LAN boot (which is what this Realek PXE message you’re seeing is). PXE boot is a common sign of a bad hard drive or bad OS, but often a bad drive. If you see the hard drive, run Hiren’s Boot CD to see if the drive is present and reading data reliably. Once confirmed to be good, run a SMART test and do a self-test to make sure it isn't bad.
If the drive has detection issues, do not mess with it if you need her laptop to work - replace it.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Randa Leonard будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 25
За всё время: 4,052
