The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
Lg g4 Wifi entegresini nasil degisebilirim
Lg g4 wifi problems. How can i change wifi chip
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi,
You don’t say what the problem is or what you have tried to do to fix the problem but replacing the WiFi chip seems a bit excessive.
Have you tried disabling the smart network switch to see if this fixes the problem?
Here’s how to do this:
Enable the mobile data connection.
Then go to Menu -> Settings -> Wireless and uncheck the smart network switch option
Your internet connection may not be so stable anymore as it won’t be switching between the WiFi and the mobile network internet connection trying to achieve the most stable connection possible.
Also try wiping the cache partition in case there is corrupted cached data that is affecting the WiFi
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
I did what they said but it didn't improve
из
@Yusuf Sonmez
Please Unaccept my answer as it didn't work for you.
What is the problem with the WiFi , you didn't say?
из
Добавьте свой ответ
Yusuf Sonmez буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 265
