Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
Home Button not working
Perhaps someone can help me. I just disassembled mine and got to the very end. I can't see anything wrong with my home button. The Apple tech said it was just some prongs that needed to be bent back, but I don't see anything like the prongs. My home button stopped functioning completely. Should I just replace the entire home button and ribbon, or should I replace something else, or are there really a couple of prongs that need to be bent back?
Это хороший вопрос?
Оценка -1
1 Комментарий
Thanks. That worked. Extremely time-consuming and by far the most difficult task I've ever completed, but it works perfectly.
из
Добавить комментарий
1 ответ
Выбранное решение
I just replaced mine, there are no prongs. It's the entire home button and ribbon that need replacing. It's all one piece.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks. That worked. Extremely time-consuming and by far the most difficult task I've ever completed, but it works perfectly. (I commented on this above, before it was an answer, so it shows up twice.)
из
Добавьте свой ответ
jkgarrett17 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 836
