13-дюймовый MacBook Pro, выпущенный в мае 2020 года, оснащен четырехъядерными процессорами Intel 10-го поколения Core i5 и i7 и интегрированной графикой Intel Iris Plus. (Модель A2251/EMC3348 с четырьмя портами Thunderbolt 3)
69вопросов Показать все
Bent MacBook body and cracked LCD along with trackpad coming out.
Hi, I’m an owner of a MacBook Pro 2020, my model number is A2251.
Due to my MacBook case being bent the trackpad is coming out, I want to change the body of it, long with the keyboard, as I bought it in turkey.
Due to me being a developer, and cause I did not submit my code, I wasn’t able to get my money.
So I will fix the screen later on, but I still need help for that in the future.
I checked for A2251 on the shop, and I couldn’t find the body.
Это хороший вопрос?
Оценка 0
2 Комментариев:
Can you post some pics so we can see more clearly the damage Adding images to an existing question
Also what is the keyboard layout (take a pic so we can see as well)
из
Alright, i have a video of it.
I sent it to a friend of mine.
из
Добавить комментарий
1 ответ
I’m not sure if replacing the parts is the most economical solution here given what you need to replace.
It might be cheaper to get a second exact system (new or used) to transfer your logic board so you can gain access to your files if that is the current issue.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
True, but a device is expensive in turkey.
As most second hand mbp's are old.
из
Добавьте свой ответ
Aramis Eraslan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 86
