Игровая приставка от Sony Computer Entertainment, анонсированная 20 февраля 2013 года и выпущенная 15 ноября 2013.
Вопросов 20 Показать все
How to fix my fan solder point
my ps4 fan connector was bad so my dad cut it off and also removed the connector on the board then soldered the fan wires to it. we tried it without the case and after turning it on it was okay for a few minutes until there was a spark and then some smoke from where the fan was soldered and we immediately turned it off. upon inspection we realized that one of the solder points were burnt off and apparently it was the gnd point, is there any way to fix this, like by soldering the gnd wire to another part of the board that has gnd?
Это хороший вопрос?
Оценка 0
2 Комментариев:
Hi! We do need some photo's before we can answer your question.. Sorry.
из
bubblepunch post some pictures with your QUESTION showing all of this Adding images to an existing question
из
Добавить комментарий
Ответов (1)
I would like to see an image regarding this to help you correctly.
But it is possible to run jumpers to restore damaged pads but like i said would be better to see an image first.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
bubblepunch будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 179
