Why is there no video?
So my GameCube has no video, but it has sound. Further inspection shows that only the red input is working and not the white and yellow.
i tried switching cables and that didn’t work.
thanks in advanced
Это хороший вопрос?
thanks in advanced
Это хороший вопрос?
Hi,
Here’s a video that may be of some help with locating the problem.
Also here’s the ifixit Nintendo GameCube guides as well which may help with getting access to the component parts
Был ли этот ответ полезен?
How about check to see if the video connector has a bended pins or damaged pins?
There at no bent or damaged pins
За последние 24часов: 5
За последние 7 дней: 48
За последние 30 дней: 209
За всё время: 7,193
2 Комментариев
Hi,
Have you proved that the the AV input (yellow - video + red & white - left and right audio) on the device (is it a TV?) that the game cube is connected to is working OK, you didn't say? You only said that you changed cables.
Try connecting another device that has an AV output to the device, e.g. a dvd player and check that there is video and audio when using it to determine whether the problem is in the game cube or not.
из jayeff
Hi! So I tested the same cables and TV with another GameCube I have, and it works fine.
Thanks!
из David Lank
