High CPU temps while idle
I have Arctic MX-4 on this computer.
I have TG pro and Macs Fan Control. TG Pro is a little confusing and honestly it doesn’t work better than Macs Fan Control.
So I have replaced the thermal paste twice with the same paste now. I’m having like a hard time to make this time stay under 65C when browsing the internet using Safari. Im thinking about using Grizzly’s Kryonaut.
What’s the regular temps for this thing? I not sure if my heatsink has gone bad. Maybe?
I made sure that to tighten the screws correctly on his heatsink. Maybe I should buy new paste and a new heatsink and see what’s up.
What do you guys recommend?
Это хороший вопрос?
What do you find confusing with TG Pro?
I find it much easier to set thresholds and it's easier to read, offers a high water mark, and it offers logging!
из Dan
@pigoath - How about posting a snapshot of TG Pro so we can see what you're facing Adding images to an existing question
из Dan
@danj The fan speeds are not going up after I set it up.
из Pigoath
@pigoath - I need to see the sensors at the bottom that got cut off (heat sink proximity). Can you take a second set of captures top and bottom at the same time point.
из Dan
