Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
iPhone got wet and now screen is very dim.
My iphone got wet in a washing machine and than it was working properly. but suddenly its screen become very dim. I can see only under bright light.
can anyone help me to fix this problem
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Выбранное решение
I am not sure about replacing the display or the logic board, that's like using the big guns right away. If you are handy, try to replace the coil on the logic board first. A lot cheaper...you can get the 6R8 coil on eBay and many other places or from here and if you are wondering how to do it, you can watch a video.
Был ли этот ответ полезен?
Оценка 2
Have you thoroughly dried out your iPhone? If not, then you may want to use the Thirsty Bag to get all the moisture out of your iPhone.
If you still have the same problem after drying, then you probably need to replace the display or the logic board.
iPhone 3GS Display Изображение
Продукт
iPhone 3GS Display
$19.99
Оценка 0
Old Turkey is spot on here.
First call would be the 6r8 coil.
If still dim then I would replace the screen but more than likely it will be the 6r8.
Dont replace the logic board until all esle has failed.
Its expensive and usually un-necessary!
Оценка 0
Добавьте свой ответ
bobby будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 8,874
