PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
DS4 not holding charge
(all this is with the included micro usb charger) I plug it into the box/outlet I use to charge other things but it doesn’t even show it’s charging. I plug it into the ps4 itself and it blinks yellow like it’s charging but the second I unplug it, it says low battery and turns off.
Это хороший вопрос?
Оценка 0
2 Комментариев:
I had a similar problem. Is the controller new or has it already been used a lot?
из
Its relatively new. Couple months ago. Got it like June/July
из
Добавить комментарий
Ответов (1)
take the controller apart and check if battery pluged in
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Heberto Moreira будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 46
