4th Gen Nano causing iTunes to Freeze
So I recently purchased a 4th Gen iPod Nano and plugged it into my pc to do a wipe and fresh install. However when I plug it into the computer, it causes iTunes to freeze until I unplug it. Then iTunes works just fine. I’ve tried different cables as well as usb ports and nothing seems to work. The device charges off of plugs just fine and works with the music that is already on it, but will completely lock up iTunes if I try to hook it into my pc.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
see if 3rd party software can communicate with it, like 3utools. It’s free chinese software that does a great job, unlike a lot of the spammy stuff out there.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
@jessabethany - Happy to see you back!
из
Добавьте свой ответ
Dan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 56
