The Razer Kishi is a universal mobile gaming controller that fits most smartphone devices, designed to bring console-level control to your on-the-go gaming. It was released in June, 2020.
9вопросов Показать все
Specs on the "button covers" (tactile domes)?
I am looking to replace/fix the D-pad and XYAB buttons so that they are less mushy. Is there any information about how these could be “fixed” with aftermarket components to make the buttons less mushy?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi Jeff,
we have a guide in the making for replacing the D-pad. It should be live soon.
There you’ll be able to see the build of the D-pad and can experiment with different “mods” to it.
In the meantime you could bend the metal spring that pushes the pad back up to your liking or you might want to add a thin extra layer between the pad and its rubber part so the connectors on the rubber part make contact with less travel.
Good luck with finding the sweet spot and think about sharing any findings for others to learn and improve their gamepad from.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Looking forward to your D-pad guide!
из
I guess you’ve already checked it out. If not, here is the D-Pad guide:
Razer Kishi Direction Pad Replacement
из
Добавьте свой ответ
Jeff будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 220
