2nf Capacitor next to Touch Filter on 12.9 gen 1 pro
Can this capacitor be found on other boards?…ie iphone ipad
Also, is this 2nf spec taken from it mounted on a logic board?
Это хороший вопрос?
Оценка
0
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 54
2nF is the Capacitance what about Working voltage, Tolerance and size?
из Chris Stables
I have no idea, I got the spec from the image posted by one of the members here (old man??)
was hoping someone had already found it on iPhone boards
из Steven Whatley
I thought this post came under Pro 12.9 so the location of the 2nf would be known. I am new to the forum, so to be clear, it is on a 12.9 Gen 1. Hope that helps.
из Steven Whatley
The chances are you don't need a capacitor there.
из Roman Prochazka
Not sure I want to remove the capacitor as there is also a capacitor in between the two back light filters. I’m thinking there’s a reason for those to be there. The main reason I posted this is because they are so easy to knock off and lose when you’re changing out the touch filter.
из Steven Whatley
