The LG G Pad 8.3 4G is an 8.3 inch (21 cm) touchscreen tablet that was released by Verizon in October of 2013. The tablet can be identified by its FCC ID : "ZNFVK810" at the bottom of the back cover in black ink.
2вопросов Показать все
Replace broken charger port
How do i replace charger port for tablet? I have taken tablet apart and determined port damaged. Grandchildren playing on tablet while it was charging. Need instructions on replacement. Can order part from Walmart.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
If you’re comfortable with a soldering iron you can attempt to replace the charging port yourself, but judging from this video: https://www.youtube.com/watch?v=P0FhFsah... it doesn’t look like it’s just a case of removing the old one and sticking a new one in since it’s soldered to the main logic board.
Был ли этот ответ полезен?
Оценка 0
Hi,
Here’s a video that shows how to disassemble a LG G Pad 8.3 V500 (if this is your model variant, you didn’t specify).
It is useful because at 5:35 minutes into the video the charge port flex cable (supplier example only) can be seen being removed from the tablet. The charge port is part of the flex cable module
There are other suppliers of the part online. Just search for Charging Port Connector Dock Flex Cable For LG G Pad 8.3 (insert model number e.g. V500 or VK810 etc)
Оценка 0
4 Комментариев:
Flex != Port :)
из
Hi @bramdriesen
Not sure what you meant by your comment but the charge port is mounted on the flex cable so no need to replace the port it is easier to replace the complete flex cable module.
Cheers
из
@jayeff True, but thats also a valid point, but if nothing is wrong with the cable, and if you can solder why not do that? :-)
из
@bramdriesen
It may be easier to replace the cable than to find the exact replacement USB port as there are very many different USB connectors of the same type i.e. micro, standard
The main difference being in the number and location of the mounting lugs on the USB body besides of course whether they're through hole type connection, smd type, 90 deg pins etc.
They can have 2 or 4 mounting lugs and also the exact point as to where they are located on the case can vary and this has to align with the solder pads on the cable or circuit board etc which makes it time consuming to find them unless you're lucky enough to get them using the device model number in the search
Also given the price of the replacement cable in this instance and if you're not that proficient at smd soldering (not everyone is) made worse in this case because it is on a flex cable and not a pcb it is probably the better option.
Cheers
из
Добавьте свой ответ
Wendy O’Steen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 533
