Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Trying to fresh install after new SSD fit?
Hi again all,
Got a 2011 21.5” iMac which I’ve just fitted an SSD into and now I’m trying to get any OS on it not just Lion which it is trying to get from Apple.
I only get the message unable to download all the nescessary files. I’ve had a look around the net and alot of people are saying set the clock back. tried this via terminal and set it back to just before and just after build date to no avail.
I have tried internet restore with WiFi and Ethernet-no joy! I only have windows PC to get other software! any ideas people…….please!
Это хороший вопрос?
Счет 1
5 Комментариев
i honestly dont know, but what i did when i installed a new ssd in my 2014 21 inch iMac i just made a macos Big Sur butable USB wich is easy to do you just need another mac to do it with, the notable USB can be of any os that you want to use or that your mac supports even apple has an article on how to do this after you have the USB drive just hold the option key after pressing the power button and then select the USB then eras and format the SSD in disk utility and then go back and click reinstall macOS and then all you need to do is wait, I would look up a youtube video on how to do this, it's not that hard so yeah hopefully I can help you out. lol, this is the first question I answer.
link to how to creat a bootable USB drive: https://support.apple.com/en-us/HT201372
The link I use to get the macOS download which you need to make the USB bootable drive( this is to gest older macOS like Catalina, Yosemite, or el Capitan):https://support.apple.com/en-us/HT211683
Have a nice day :D
из
Thanks Apple,
из
Hopefully I could help when I sent the message I didn’t realize someone had already replied to your question so yeah, have a nice day
из
Hi Apple, thank you for your message, yes Dan has been really helpful but i appreciate anybodys input!
из
Ah ok haha no prob then, happy late Valentine’s Day ?
из
Добавить комментарий
2 Ответов
Выбранное решение
Sounds like you still have a working HDD which you took out is that correct?
If you do we can get you going but you need a SATA to USB adapter which offers power for the 3.5" HDD you took out. Or... You need to put the HDD back into your system and then get a 2.5" SATA to USB adapter.
Once you have the drives setup you should be able to then boot up under your HDD to then download a newer version of MacOS. I strongly recommend you stick with Sierra (10.12.x) as its the best one for your system. Download the OS from here How to get old versions of macOS You’ll then need to create a bootable USB Thumb drive OS installer. First format the USB Thumb drive to GUID with a jounaled file system and then follow this guide How to create a bootable macOS Sierra installer drive.
Once done you can swap the drive again so you have the SSD installed. You may want to consider adding the drive Vs swapping it! Your system offers a spare SATA port which you can use to connect your SSD as a second drive Installing iMac Intel 21.5" EMC 2428 Dual Drive Kit. I strongly recommend that if your HDD is still running. Then you can gain the speed of the SSD as your boot drive and holding your apps, and still have all of the storage you currently have on the HDD for your media and other stuff.
Turn your current hard drive into an external drive with this adapter. Изображение
Товар
Universal Drive Adapter
$24.99
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part. Изображение
Товар
2.5" Hard Drive Enclosure with USB 3.0 Cable
$12.99
Был ли этот ответ полезен?
Счет 3
22 Комментариев:
Hi Dan, thank you for your advice. Re the original HDD, i dont want to re-use it as it was unstable when i got the machine and i had exactly the same problem getting it to accept an internet reload, hence the upgrade to an SSD. I would be interested to know why the internet restore option wont work. Is it down to the lack of support from apple for this OS or is it the date/time issue.
из
Hi again Dan, following on from my earlier response i have managed to get the old HDD in an enclosure and attached to iMac and have managed to get it formatted via MAC OS X utilities. So basically i have an SSD installed in the machine and the HDD in an enclosure external to the IMac. Neither will accept an internet load and keep returning the same "cannot download the required components to load OS X". This is clearly a apple server issue with my iMacs' age i'm thinking.
из
@aerobob - Tell me you didn't format the HDD !! I wanted you to leverage it to setup the USB Thumb drive.
Forget Internet recovery!! We need to use the 100% workable solution Apple has not maintained the older OS's on their Internet recovery servers which is why you are encountering a problem.
Here's the basic issue: If you've got an old macOS install image, it will probably stop working today
So lets get the USB OS installer setup!
из
Are you refering to the comment by Big Dan?
из
Do i need to back date the system clock as Dan has suggested first?
из
Показать ещё 17 комментариев
Hello, I thought I was alone in this struggle. Same EXACT issue... I've tried everything. I have two 09 iMacs running El Capitan and I can not get them out of recovery. I've tried the server download (403 forbidden error), tried the time change but also doesn't work. I can't get them to recognize the bootable USB drives. But then in disk utility it's there. Why apple would make it so overly complicated to install an OS into a new drive is beyond me lol - Please help!
Счет 0
1 Комментарий:
time to create a bootable OS installer or dig out your old OS-X OS recovery CD/DVD’s to find the one that will boot up your system so you too can nuke your drive back down to nothing! Of course you’ll want to first backup your stuff so you can recover the Apps and data you currently have.
Depending on your Mac you might be able to use a USB thumb drive or you may need to dig out an old FireWire drive to setup the needed bootable OS installer.
How about telling us what the two systems are so we can help you.
из
Добавьте свой ответ
Bob Taylor буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 21
За всё время: 277
