Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
87вопросов Показать все
will MacBook Pro retina 13" keyboard ribbon fit my MacBook?
I managed to tear apart my keyboard ribbon that connects the motherboard to the keyboard during thermal paste replacement and now I have no keyboard functionality because of the missing ribbon connector for keyboard. Will another keyboard ribbon from Macbook pro 13” 2019 function? Any other ribbon except the OEM one? Thank you so much!
Это хороший вопрос?
Оценка 0
1 Комментарий:
Ouch! Yes you do need a new cable how does the logic board & upper case connectors look? Are they OK.
из
Добавить комментарий
1 ответ
No! You need the 15” cable MacBook Pro 15" Retina (Mid 2018-2019) Keyboard Cable
As you can see the 13” is very different! MacBook Pro 13" Retina (Mid 2018-2019) Keyboard Cable
How about posting some pictures of the damage so we get you what you need as your description implies you have logic board damage. Adding images to an existing question
MacBook Pro 15" Retina (Mid 2018-2019) Keyboard Cable Изображение
Продукт
$19.99
MacBook Pro 13" Retina (Mid 2018-2019) Keyboard Cable Изображение
Продукт
$14.99
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
The ribbon is clearly torn. Macbook is able to turn itself on and will function as standard, provided I connect an external keyboard to it. Thank you!
из
Добавьте свой ответ
KeyBoardER10 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 22
