Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577вопросов Показать все
Small White Spots after screen replacement
After replacing my digitizer, I proceeded by wiping the lcd with a microfiber cloth. I think I wiped a bit too hard and there are faint white spots when displaying something with a black background. Is there any way to fix this?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Those could either be pressure points meaning something is under the screen pushing up on it or it could be a defective LCD. If you can get that screen off in one piece as those spots disappear then something is putting pressure on the display. If they’re still there when you lift the screen off then it’s a defective LCD and you should contact the supplier to get a replacement or refund depending on their policy.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
jimmysofat6864 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 155
