Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455вопросов Показать все
accidentally dumped sanitizer on my 3DS and it won't turn on
ok I accidentally dumped sanitizer on my 3DS and it won't turn on I put it over our heater and it won't turn on I'm going to try this
Update (02/23/2021)
I had a water balloon but it was filled up with hand sanitizer and I popped it on accident andand it got on the right side of my de tendo 3DS and it won't turn on I need help please help me please please
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi
The impurities in liquids (except distilled water) causes corrosion and provides circuit paths for the electricity which were not in the game console’s operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your console and then remove the battery as soon as possible from the console to minimize any further damage.
Then you need to dis-assemble the rest of the device and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible, do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there as well. The ends of any flex cables and their connectors need to be cleaned also.
Hopefully after you have done all this the console might possibly work correctly again.
Here is a link to the ifixit Nintendo 3DS guides that will help
If this process seems too daunting, take your console to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later. It isn’t going to fix itself
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
ronin dampier будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 86
