After changing the digitizer on Apple Watch 4 touch don't respond
Hello, After changing glass and digitizer on Apple watch series 4 40mm, the touch screen don’t respond.I thought the purchased digitizer did not work so I re-installed the new digitizer but it still does not work.I think the connecting cables were not damaged during the repair. any solutions? Does changing the display flex cable help this problem?This is a picture of the digitizers I bought
Это хороший вопрос?
Оценка
0
Hi, this might sound silly but did you restart the watch? Sometimes a cheeky restart will fix it
из Roman Prochazka
@pomikoli sure, i tried thousand times but didn't help
из Tornike
haven't done one
however do they have a seperate screen and digitiser
and I'm guessing you replaced the screen ?
try cleaning the connectors with alcohol?
из Gerry Golden
@golde They have only glass and digitizer together, no i dont replace lcd screen. i replaced only digitizer.
из Tornike
@atmx does the old digitizer work
if it does it could be paired to the device
из Gerry Golden
