Samsung Fridge MSV488A-L1P has water leaking
G'day, my Samsung Fridge MSV488A-L1P has water leaking
1. at the bottom of the fridge.
2. a thin layer of ice inside the fridge tray/pan.
Please help.
Thanks
Lee
Это хороший вопрос?
Please help.
Thanks
Lee
Это хороший вопрос?
Hi,
Please verify the model number of the refrigerator, as the model number that you have posted appears to be for a refrigerator compressor (find it in the list of compressor models)? Knowing the correct refrigerator model number will help to find the correct parts etc if there is a faulty part that may be causing the problem.
Water leaking and ice forming in the freezer compartment sounds like a defrost problem.
It could be a blocked drain that goes from under the evaporator unit inside the freezer compartment and leads to the evaporator pan under the compartments.
This drain allows the meltwater from the defrost cycle to drain away and evaporate naturally. If the drain is blocked the meltwater backs up and overflows back into the freezer compartment and when the defrost cycle is over it refreezes again.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 286
2 Комментариев
Samsung compressor power catalogue send me
из Muhammad Yaqoob
@Muhammad Yaqoob
Click on the link in the Chosen Solution below to find the specifications for the compressor model numbers listed.
What is the model number of the compressor or what is the model number of the refrigerator where the compressor is located?
из jayeff
