2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265вопросов Показать все
New display but still nothing on screen
I replaced the screen on my laptop because it wasn’t working, but the replacement screen isn’t working either.
The computer will run in clamshell mode, but I’ed really like to be able to use it as intended.
Is there another part that could be the problem? Not sure how to go about further diagnosis.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Let’s do some checking! Using a flashlight aimed through the Apple logo in the lid (a poor mans backlight) are you able to see the faint image of your desktop and its icons? If you do the issue is the backlight logic on the logic board not the display its self.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
That worked! So, now the question is what do I do now? Replacing the logic board sounds like a major job.
из
Not that drastic! Your logic board needs repairs not replacement.
Where are you in this big blue marble? Country and nearest city, maybe we can aim you to someone.
из
Добавьте свой ответ
Ian Jackson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 29
